cpu: i7-4770k
mobo: asus z87-a
gpu: gtx 670 ftw
psu: corsair hx850
ssd: samsung 128
monitor: benq xl2420te
hi! i dont know if i am in the right section but the story is...
my gpu is having a coil whine, the gpu is a year old now, for me, i can tolerate the noise of the coil whine,the coil whine occurs when my fps goes above 60 fps while playing,, but just a month ago, the display starts flickering randomly when im in game or just in idle, well it flicks just for .01 sec.. i thought its just the cable but when i hooked my dvi cable to the mobo, it doesnt flick at all,so its not the cable, the next thing that i did was test the monitor, i used my ps3 to test it, and it doesnt flick at all, so its not the monitor,. i said to evga about this and i was approved to rma it, so i did. After i received the package, and install it on my pc, my display still flicker and the coil whine is still there. so i contacted evga again about this and they told me this, " You will want to see if the PSU is providing consistent power with the card installed. Turn on your computer, Go into your BIOS and look for the +12v reading, this is typically under 'PC Health Status', System Monitor, Hardware Monitor'. A healthy reading (official ATX spec) is between 11.4 - 12.6v, and stable. No fluctuations." so i did, but i just found in monitors is something like, 3v, 5v, 12v, so i dont know what im talking about now, and i dont know how to check the status correctly,
sorry for bad english =) but i hope you guys understand my problem, i can provide more info if needed,
mobo: asus z87-a
gpu: gtx 670 ftw
psu: corsair hx850
ssd: samsung 128
