There is a video on YouTube , the man in the video says that modern CPU Consumes absolutely no watt at start up ~ 0 Watt ,
Therefor if you are using a PSU with ATX 12V v2.2 it won boot .
This Problem is solved in ATX 12V v2.3 PSUs .
How true is this statement .
I am building a pc with i3 3220 and GA-b75m-d3h , i read the manual of motherboard , there is absolutely no information regarding this .
also there is no strict rule , that if you are using ivy bridge you should use ATX 12V v2.3 PS.
I want to use My two year old PSU which is ATX 12V v2.2[ it has all required connector 24 pin,8 pin ,and other] with core i3 3220 and GA-B75M-D3H.
I have never seen something like this but i don't know.
So is it going to be problem or i can safely use it ?
Link to the Video :http://www.youtube.com/watch?v=_yiNEZWpLZ0
Read the comments
Read the comments
