i'm considering between ......Super Flower Leadex III 550w (full modular).......vs......Seasonic Core GM 550w (semi modular).......
the Leadex III has Japanese capacitors (main board + modular back panel) and Grade A Taiwanese capacitors (modular back panel).......but has a fluid dynamic bearing fan........................the Core GM use 100% Japanese capacitors.........but has a sleeve bearing fan...........🤔
i'm worried the Core GM's sleeve bearing fan will break down 1st........but it has 100% Japanese capacitors...........but isn't the Leadex supposed to be competing against the higher model Seasonic Focus series ?🤔
also, there are capacitors on the cables........so i'll need to replace the cables when the capacitors die off ?😱
