PSU Cable Extension Kits?
HTTPRO
70
Can you directly PLUG the extensions to your PSU? I have a Corsair HX750 and I want to use pre-made extension cables. I also wanna know the best ktis you can get in Canada, I've tried searching up cable extension kits but only US comes up.
You can use extension cables if you need to. If you don't need to, then don't do it because it slightly increases powerdraw (longer cables waste more power) and it gives more fault points, especially with cheap cables that aren't thick enough. I don't know what kits would be best. It usually isn't expensive, but getting extensions that connect to the cables instead of the PSU is usually easier.
Where do you get this information from? It's scaring me a little to get these extensions now...
Thanks, when I was searching it up only Silverstone Cables were coming up and I'm not sure they're compatible.
