PSU cable replacement
timothybrey
Commendable
Dec 21, 2017
72
I have a dell t3500 and want to upgrade the graphics card from Quadro 4000 to Gtx 1080, but the 1080 takes one 8 pin pci-e and my psu only has one 6 pin. I have the 875 watt dell H875EF-00 PSU. It was plenty of power but I can't use a gtx 1080. It has the plug in cable, (the one that just plugs into the PSU and has all the other ones coming out of it,) is there any way I could replace just the cable without having to spend $200 on a new PSU?
Your not going to find a replacement cable with an 8 pin pcie connector.
When they came up with the extra power plugs for video cards, they made 2 flavors. 6 pin and 8 pin. If you look at both you will notice they each have 3 12V lines (normally yellow). So, they supply the same amount of power, right? No ... the 6 pin is rated for 75 Watts and 8 for 150 Watts. This means the 8 pin may have thicker wires and the components in the power supply will be rated for more current. Now, there are companies that sell a 6 pin to 8 pin converter and they work ... until something melts ... maybe. When you draw 150 Watts of power over wires and components that were made to a 75+ Watt standard sometimes they work and sometimes they melt. So...
When they came up with the extra power plugs for video cards, they made 2 flavors. 6 pin and 8 pin. If you look at both you will notice they each have 3 12V lines (normally yellow). So, they supply the same amount of power, right? No ... the 6 pin is rated for 75 Watts and 8 for 150 Watts. This means the 8 pin may have thicker wires and the components in the power supply will be rated for more current. Now, there are companies that sell a 6 pin to 8 pin converter and they work ... until something melts ... maybe. When you draw 150 Watts of power over wires and components that were made to a 75+ Watt standard sometimes they work and sometimes they melt. So, avoid something like:
https://www.amazon.com/StarTech-Express-Power-Adapter-PCIEX68ADAP/dp/B001TK3TJY
$200 for a new PSU ... that's a pretty nice PSU. May I recommend:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151186
https://www.newegg.com/Product/Product.aspx?Item=N82E16817438094
Assuming they fit in your case.
Ok thank you.
