PSU + Case Help? :)
-_Maverick_-
Commendable
Mar 25, 2016
Hi,
So I'm just about done planning my new gaming rig. But there COULD be a problem...
I know it SHOULD work but better safe than sorry.
It's regarding the PSU and case.. Sizewise. The case says it supports a max PSU length of 220mm and the PSU has dimensions of 31.9 cm W x 21 cm H x 16.3 cm D.
PSU: http://xfxforce.com/en-us/products/xtr-series-gold-full-modular/xtr-series-650w-psu-p1-650b-befx
CASE: https://www.pccasegear.com/products/34234/corsair-carbide-600c-inverse-atx-full-tower-case
Thanks.
What you listed for the PSU is the package size (whatever that is), not the PSU size. There is no way that the PSU is more than 12 inches long! It will fit. Actual dimensions listed by jpnnyguru are 170 x 150 x 86 mm.
