R Rburma Distinguished May 16, 2009 1 0 18,510 May 16, 2009 #1 I'm building a new P.C (790GX, Phenom II 955, HD 4890, 1tb SATA 3gb/s HDD, 8gb DDR3 1333) How hefty of a power supply do I need to buy, and would all of this fit into a mid ATX case?
T tidefan94 Distinguished May 6, 2009 86 0 18,640 May 16, 2009 #2 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004 This should be more than enough And it should fit into a mid ATX case, but which one are you using?
xthekidx Splendid Dec 24, 2008 3,871 1 22,790 May 16, 2009 #3 Here is another option that is a little cheaper: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010 Do you have plans to overclock your system? And what case are you planning on using?
