i'm not sure if this is the right type of thread as i did not see one for PSU.
Hey i need to some expert help with this PSU i have its an Eagle Tech Voltas ET-PSVT500. This is going to be weird to explain but i cut the molex connectors off the PSU a long time ago to power a car amp to drive 2 150Watt subs for my surround sound. While i was watching 2fast2furious the subs stopped and i walked over to the PSU and the fan wasnt spinning. So i took it to the garage cleaned all the dust out of it and plugged it in to make sure it still worked without it being connected to the amp and the fan was spinning very slow, so i thought to myself the power supply still worked. Well i plugged it back into the amp and now i have a coil whine and no fan spin. i did spin the fan by hand while the PSU was off thinking maybe its stuck and it spun smoothly, i then turned the PSU on the fan spun very slowly at first then stopped. every time i turn the PSU i hear a coil whine. Should i throw it away and get a slightly more power PSU or is it safe to use still? If i have to throw it out and get a new one what is the cheapest 500watts or more PSU some of you would recommend? Thanks in advance
*update I realize a name brand would be better than off brand. I'm not looking for the best PSU i'm just looking for one that will drive the subs.
