PSU Compatibility Issue with Rampage V Extreme?
kcvogel9
Hello,
I have a build that I completed over a year ago but have been experiencing problems with almost from the start.
Build details here: https://pcpartpicker.com/list/rDZXr7
The problem I am having is that I have to unplug the computer from the wall for a period of 1 hour or more before it will attempt to start again after it is shut down or goes to sleep. (And when I say Start i mean the fans don't try to spin up, the hard drives don't start up, nothing. The lights on the motherboard are lit up though, but the Q-Code LEDs aren't lit up and the Q-Code cycle doesn't start either)
I have RMA'd both the motherboard and the PSU. The odd thing is that the system will work properly for a period of approximately a week if both components are new (this has happened twice) but will eventually fall back in to the same problem.
I am honestly at a loss. The system works fantastic when it is operating properly, but there seems to be some sort of compatibility issue between the EVGA 1050G and the Rampage V Extreme. Is this even possible?
Thank you for any assistance, I am pulling my hair out trying to figure this problem out!!
Hi, thank you for the reply, I had not downloaded CPUID, but I just did! Which item should i look at to identify if the North Bridge is overheating please??
