PSU Compatibility with components.
Victor Aro
30
Hello!
I am getting a new PSU for a upgrade in my system that includes:
-GPU:
-RAM:
-CASE:
http://www.kabum.com.br/cgi-local/site/produtos/descricao.cgi?codigo=54209 (cant copy the image url for some reason)
-CPU:
AMD FX 4300
-The PSU: http://www.kabum.com.br/cgi-local/site/produtos/descricao.cgi?codigo=36436 (Description in the website, its in portuguese but should be easy to find)
And i allready got the MOBO:
My question is, Will that PSU give me everything i need to make my system work? if not, what would you recommend?
Either of those would be a much better unit than the first one you listed. I think SR-71's had experience with the cx500 but not sure.
I really don't know. I tried to translate the product page and it looked like the 12v only offers .3 amps and 14 amps which doesn't sound right at all. I'm thinking the translation didn't give accurate information and I'm not at all familiar with that brand. The brands on that site that I am familiar with are much more expensive from the looks of it although I don't know exactly how the currency translates to usd. It says "R", what currency is that?
It was kinda confusing for me to xD
Well i think i will get an EVGA 500W 80 Plus White PSU or a Corsair CX500W because they have everything i need...
What is the best in your opinion?
R$ is brazilian reais, 4 R$ is basically 2 USD.
They will probably fit in that case...
