PSU Custom Cable Sleeving
RightHereBro
92
I have this PSU: XFX TS550 80+ Bronze,
and i want to sleeve the cables,i can unplug the adapters i try it with an old psu but i am a little afraid doing it.
I unplug one cable each time, then sleeve it plug it again and then go to the others.
What are the risks of doing it to my psu?
Any potential dangers for the psu or my system?
What should i be careful?
Hello,
HIGHLY DO NOT RECOMMEND.
Its definitely possible, but breaking even 1 plug (out of 50+) and you're going to be regretting it. I can help you get another plug if you break 1, but it would take a few days.
Then i am thinking buying some cable extensions and unplug them and sleeve them ,so i can get cheap sleeving in cables and have my psu save what do you think?
