Hello, I changed the fan stock PSU (GX650w) to an "Akasa Apache 120mm".
I plugged in a molex and the noise is a bit loud. Would it be safe for the PSU to connect the fan to a 7v splitter? I have a very old configuration, so I do not use the 650w. What is the acceptable temperature for the PSU?
12v = 1300RPM
7v = ???
/// Apache
- Speed: 600 - 1300 RPM
- Airflow: 57.53 CFM
- Air pressure: 2,64mm
- Noise level: 6.9 - 16.05 Dba
- voltage: 12V DC
/// Configuration
CPU: Phenom II x 6 1090T
CPU Cooler: Cooler Master - Hyper 212x
Motherboard: M4N68T-M LE
Memory: 2x Corsair Vengeance 4GB 1600Mhz DDR3
Storage: 2x 1TB HD 7200 RPM
GPU: RX 460 2GB PowerColor Red Dragon
PSU: Cooler Master - GX 650w
12v = 1300RPM
7v = ???
/// Apache
- voltage: 12V DC
/// Configuration
