PSU - Seasonic Focus GM650
PC randomly shut down a couple of times then showed DRAM light so I cleaned and checked each stick. While I was doing that my pc for a few mins just would not turn on. No response after pressing the power button. I cleaned the and other components while waiting for a few mins and it fixed itself so I got back to work.
PC then again shut down this time it just won't start so i took out the psu, shorted the two motherboard cable pins to start it without a pc to check what the culprit was and again no response. I tried 4-5 times then gave up. Just went back to it after an hour to check again and this time it turned on and still running.
Any idea what could cause this timeout that was letting my psu from turning on?
Update: after it running empty for 15 mins I turned it off and then on again. And it won't turn on again
