Question PSU doing deep rumble noise depending on its position
ACosta77
13
I forgot to take the name and model of it but it's 6 years old now, 350w PSU.
So the PSU is on the top of the PC, fan facing down. Once I start the PC, it makes a deep noise. Don't know how to really describe it. Anyway, once I go to desktop and wait for, maybe 2-3 minutes and restart my PC, the noise is completely gone. It's like it never happened.
If I put my PC on its side (fan facing left or right), it does not make any noise. Like it should. I have no idea what it could be. I've tried jump short it but the results are the same.
The noise doesn't seem to be coming from the fan.
Any ideas?
ACosta77
13
Same reason a worn out engine can sound rattly but stop when it warms up--the heat reduces the clearances enough to make it quiet. You could test this by preheating it with a hairdryer.
The fan should be replaced--no telling when it'll seize up on you.
Yep, if I heat it with a hairdryer, it starts normally, no noise.
Sounds like an unbalanced fan.
What is the make/model of your psu?
What is your graphics card?
A 6 year old 350w psu may be a cheap one which you should consider replacing regardless.
It's my grandparents, its an AMD APU A8 3850. They really only use it for very very basic browsing.
I will tell them to either replace the fan or just replace the PSU.
