psu fan has a connector 3 pin connector - can i use a 4 pin?
jamie6737
83
The new fan i want to replace my old PSU fan with has a 4 pin connector
so can i just plugin the 4 pin into the 3 pin slot on the PSU?
also is there any difference between a Pre installed PSU fan and a normal 120 mm fan?
1 Yes, you can.
2 Well, it depends on teh specific fans. You need to make sure that the fan you put in tehre starts at teh same or lower tension.
