Hello there all!
I just purchased this power supply and had a quick question.
http://www.ultraproducts.com/applications/SearchTools/item-details.asp?EdpNo=3276573&CatId=1483
If you notice the fan is on the top of the power supply, the way my case is setup the power supply is pinned up against the ceiling of my computer case. Should I cut a square out the top of my case? Flip the PSU upside down? or place it somewhere else? I want to ensure it has sufficient airflow.
Any advice is greatly appreciated. Thanks in advance!
