I have a motherboard which seems to have the power signal shorted, because the psu y cpu fan are always spinning whenever the power cable is connected to the PSU. Otherwise than that the computer seems to work normally.
I have tried different PSUs with the same result.
Disconnected everthying from the motherboard except the power supply cable that feeds the atx connector, and the processor and ram.
Can it be a bad capacitor ? it seems to me that there is small of capacitor in the lower part of the motherboard with a little bump on top of it. Should replacing it fix the motherboard ?
Is the +5VSB the signal that manages the power on and off of the motherboard ?
Thank you
Thank you
