Psu for 1600x and r9 280x
Jasper_1
6
I already own an evo212 and look for a psu for the combo ryzen 1600x+gigabyte ab350 gaming3+ Gigabyte r9 280x with a slight oc plan. My aim is at around 3.8~4.0 ghz.
Thanks in advance.
MERGED QUESTION
Question from Jasper_1 : "Psu for 1600x and r9 280x"
cpu 95, gpu 250, consider 30% more for ocing (exaggerating), plus rest sys 50, max 500 draw, get 550 good quality units :)
My pick:
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($75.00 @ Amazon)
Total: $75.00
Generated by PCPartPicker 2017-12-12 13:15 EST-0500
For budget:
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply ($48.99 @ SuperBiiz)
Total: $48.99
MERGED QUESTION
If you want to be REALLY safe and get an extra buffer, an 850W would be fine too. More than that and it's really overkill unless you plan on doing CF/SLI ever. With 850W you can even do CF/SLI with cards that don't require massive amounts of power like ours (I have a 1080 Ti) do.
UPDATE: I thought those numbers looked funny so I checked again. The CPU will do about 90W at stock, max load.
Adjusting the numbers 650W min for a buffer, 550 ABSOLUTE MINIMUM and may not be enough always. 750W if you want to be REALLY safe. 850W if you ever plan on doing SLI.
