PSU for build!
gamer9sam
29
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($179.99 @ Microcenter)
Motherboard: Asus Z87-A ATX LGA1150 Motherboard ($129.99 @ NCIX US)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory ($74.99 @ Microcenter)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Microcenter)
Video Card: Asus GeForce GTX 760 2GB Video Card ($259.99 @ NCIX US)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case ($74.99 @ Microcenter)
Total: $779.94
(Generated by PCPartPicker 2014-02-16 14:27 EST-0500)
Just looking for a good PSU that will work for this build and minor overclocking. Only asking for the PSU here and not peripherals, OS, or other upgrades.
My full build conversation:
http://www.tomshardware.com/answers/id-2027836/finalizing-gaming-build.html
Newegg has the Antec True power Classic TP 650C a 650W psu rate 80+ gold with a 5 year warr. It's made by Seasonic and is a up to date design made with high quality parts. The only down side is it's not modular, but it's only $60 after $10 off code EMCPHEF636 and $20 mir. Price is good until 2/17.
i highly recommend
Estimated Wattage: 353W
this power supply 750w you can do plenty of overclocking but not with that stock cooler also go with a cooler master hyper evo than you can overclock you're cpu at a very good temp.
PCPartPicker part list: http://pcpartpicker.com/p/q9eM
Price breakdown by merchant: http://pcpartpicker.com/p/q9eM/by_merchant/
Benchmarks: http://pcpartpicker.com/p/q9eM/benchmarks/
Power Supply: EVGA SuperNOVA NEX750B BRONZE 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($69.99 @ Microcenter)
Total: $69.99
(Generated by PCPartPicker 2014-02-16 14:43 EST-0500)
For a system using a single NVIDIA Reference Design GeForce GTX 760 graphics card NVIDIA specifies a minimum of a 500 Watt or greater system power supply that has a maximum combined +12 Volt continuous current rating of 30 Amps or greater and that has at least two 6-pin PCI Express supplementary power connectors. Some of the non-Reference Design GeForce GTX 760 cards have a single 8-pin (e.g. ASUS GTX 760 DirectCU II OC) or two 8-pin (e.g. MSI GTX 760 HAWK) or one 6-pin and one 8-pin (e.g. Gigabyte GTX 760 WindForce OC, EVGA GTX 760 SC w/ACX Cooler, MSI GTX 760 TwinFrozr Gaming) PCI Express supplementary power connectors.
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Sufficient Total Combined Continuous Power/Current Available on the +12V Rail(s) is the most critical factor.
Overclocking of the CPU and/or GPU(s) may require an additional increase to the maximum combined +12 Volt continuous current ratings, recommended above, to meet the increase in power required for the overclock. The additional amount required will depend on the magnitude of the overclock being attempted.
XFX XTR Series P1-550B-BEFX 550W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active PFC With Full Modular Cables
• OEM: Seasonic
• maximum combined +12 Volt continuous current rating of 45 Amps
• two (6+2)-pin PCI Express supplementary power connectors
• Haswell Compatible: Yes
• 80 PLUS GOLD Efficiency Certification
• 5 Year Limited Warranty
• Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817207032
Ample spare capacity to handle any overclocking of the CPU and GPU that you may want to attempt.
