PSU for Graphics Card (Please Help)
tkaizen
8
I have the following desktop -
HP Compaq dc7900 Convertible Minitower
I plan to install the following graphics card -
HIS Radeon HD 5670 512MB GDDR5
My system configuration is as follows -
Core2Duo E8400 3.00 Ghz
2GB DDR2 RAM
250 GB Seagate HDD
DVD-RW
Windows 8.1 32bit
I opened up my cabinet and saw that the PSU says 365 watt.
Will the PSU be able to run the Graphics Card?
Eagerly waiting for your reply
lite-on is cheap chineese psu but as long a its listed they are not faking it on the specs so i think is worth trying.also the 5670 as far as im concerned it drows power only from the pci express. no need for extra power.
@smeezekitty
This is what is written on the PSU -
365W MAX
+5.08V====+3.33V====+12V==
19A 24A 12A
+12Vcpu==== -12V====+5.08Vaux
14.5A 0.15A 3A
@chris987 Thank you
The UL Number on the PSU is E132068.
I looked it up on the UL Online Certifications Database.
The Manufacturer is LITE-ON.
Will the 365 Watt PSU be able to power the HD 5670?
@chris987
Thank you again
You are right. The HD 5670 only draws power from the PCI express slot.
I checked PSU wattage requirement on Newegg PSU Calculator.
I got 280 Watts.
In this case quality matter more than quantity. How well will your PSU work at near full load? I guess very poor.
I recommend swapping out the PSU for a Corsair VS450 or Corsair CX430 (Recommended), If you do this you can rest assured your computer won't blow up :).
