PSU giving me grief. need help and advice
James i5
24
Hi
I have an ANTEC Earthwatts 500D (500w) Power supply that will be taking the place of a DYNEX 520w PSU currently in my system..
Heres the problem
With the Antec PSU, i did a paperclip test to check to see if it worked.
With no load the unit powered on and the fan spun around twice then the whole thing DIED.
I later decided to add a Case Fan to it and see what would happen:
With 1 Case Fan the PSU powered on and ran the fan for about 15 seconds then died.
I Later added a second case fan.
This time the PSU powered on and ran both fans without a problem and didnt cut out on me.
HOWEVER, there is still a clicking noise coming from the PSU Fan that has clicked throughout all my tests.
My QUESTION:
1. Would this PSU be safe to put inside my rig?
It seems to run well with a moderate load.
My theory is that being that the Unit is an EARTHWATTS, Perhaps it needs a specific amount of load to function to save energy and whatnot.
PLease reply with your advice and opinions, ill read them all
No. Any power supply will supply whatever load demands your system makes big or small right up to it's load limit in watts. It either works or doesn't. Some are noisier than others. I suspect you've got a short somewhere. I would remove the motherboard and check under and around it for any loose screws, case standoffs, or backplate metal touching ports, etc. and remount the board. Also secure the extra ps wires carefully with tie downs and be sure no connectors have any stress points when connected to the board or drives.
