I have a 550W PSU with a 4 pin ATX and a 6 pin ATX connector but I'm not sure how to connect them to a GTX 1070 which needs an 8 pin connection.
I have some kind of 6+6 to 8 pin adaptor but I'm unsure if that would work.
One of the sockets appears to be missing a pin so is the idea to turn two 6 pins, or 11 pins into an 8?
Would attaching a 6 pin and a 4 pin be the equivalent of turning a 9 pins into 8?
If that's how it works then it sounds like if 11 to 8 is okay then 9 to 8 should be too but I'm really not sure.
Any advice would be greatly appreciated, thank you.
