[SOLVED] PSU help :D
KeithK2006
86
4
545
4
I'm planning on building my first pc and I'm probably going to do a bit of overclocking. I got this note on PCpartpicker: "Note:The MSI MPG Z490 GAMING PLUS ATX LGA1200 Motherboard has an additional 4-pin ATX power connector but the Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply does not. This connector is used to supply additional 12V current to the motherboard. While the system will likely still run without it, higher current demands such as extreme overclocking or large video card current draws may require it." Do I need to worry about this and get a different PSU or will the one I have work just fine?
