psu help first build noob
Iain strachan
18
here are the specs would be very grateful for help was looking at a 600w corsair
amd 8320
asus r9 270 oc
2x 4gb kingston hyper x blue
1 tb wd cavier blue
120 gb ssd kingston v300
cd/dvd burner
You're welcome :)
m5a97 r2.0 motherboard but will run win7 not crappy 8
650 w will work even though there oc cards? first time builder you see not clued up on all requirments!
im gonna have to look around im uk and us get there parts cheaper 🙁
Quality good 650W would be enough to CrossFireX two 270's
Also M5A97 R2.0 is a good motherboard for your needs. Get 650W PSU from XFX to make CrossFireX or get 550W with GTX-760!
alot of threads i have read say when oc u need headroom also a water cooling unit ?
650W would be enough (650W would be also enough for 270X CrossFireX) even with OC.
And if you want water cooling take a look at Corsair H100i and NZXT Kraken X60! or Cooler master Seidon 240
tnx i did my research as it has 9 series chipsets all the way! just hit a wall with psu's much appreciated !
Fantastic help tnx!
You're welcome :)
