Hello all, this is my first every post on this forum (which I have received much information from prior to) and I am in need of some clarity when it comes to PSUs.
I am getting a lot of mixed readings regarding whether or not 550w SeaSonic G series PSU will be able to comfortably power my build I am about to take on.
The Build is as follows:
• MSI GTX 1080 8gb - GPU
• Ryzen 7 1700x - CPU
• (1) SSD, (1) 5400 rpm HDD
• Gigabyte x370 k7 mobo
• 6 140mm case fans
• 27" monitor with keyboard and mouse
• 550w SeaSonic G 80+ Gold
As far as my desire for overclocking, since I am just delving into the vast world of PC knowledge, I will wait until I am a bit better acquainted to do much OC. However I would like to leave myself room for OC, don't know if I ever would go for an SLI setup for this build. Im going to be using the computer mostly for multi-threaded tasks, and am quite excited, coming from a MacBook Pro, for the extra oomph. With that said, the computer will commonly be at a high load and I will potentially want to push it further in the future with overclocking.
So basically I have three questions
1) Would 550w be enough for my current set up with some OC headroom or should I return the PSU I have an upgrade to a 600+ watt unit?
2) Im assuming 550w would be too low for a future SLI setup, would a 650w unit be a better investment to take into account future additions or possibly even more power?
3) What could exactly happen if the computer demanded more power than the PSU could deliver? would that cause any part of the PC to become damaged in result or do PSUs have some sort of safe guard against that?
Thanks for the time![Smile :) :)](/data/assets/smilies/smile.gif)
Ive seen calculators with a 300 watt difference in readings, people suggesting 750+ watts and others even suggesting 1000+ watts for similar builds. I figured it was overkill but seeing such a great amount of conflicting answers had me well.... conflicted!
• 6 140mm case fans
Thanks for the time
