PSU Help + GPU Help !
TheNeoNGameR321
60
Do Small form cases and tower has the different type of psu or they have the same psu and would an GT 630 support 400 w psu or 300 w and u guyz please tell me what can i write to bring small form cases psu thank u
you need to get the PSU which is higher than 350w will do....
GT630 consume about 300w hence you need to get PSU which is higher than 350w as you need to consider the CPU and the other hardwares
Can I see a picture of your case ?
These standard sizes ,
-ATX
-Micro-ATX
- Mini-ITX
can usually fit the regular ATX sized PSU.
And why bother buying the GT 630 ? It's not worth. The difference between that and integrated graphics isn't that big. A good upgrade would be the HD 6670 or HD 7750
