System Specs:
CPU: amd fx 8350 oc 4.5 GHz at 1.45v
Idle core temp 15°c
max core temp 42°c
Idle socket temp 32°c
Max socket temp 55°c
Cooler Zalman lq-310 liquid cooler
Motherboard: asrock extreme 3 970 r2.0
Ram: 2x4 gskill 1600mhz stock
GPU: Asus r9 270x 2gb
Sound card: Sound Blaster Z
HDD: 1tb Seagate 7200 rpm
Fans 2x 120mm led, 2x 120mm, 2x 84mm case side fans
PSU: coolmaster extreme 2 725w
The buzzing sounds like overhead electrical wires. It is not constant its just when its under load ( so far I have only tested this in prime 95 as I am seeing if the oc is stable). Does this indicate any problems?
Idle core temp 15°c
max core temp 42°c
