A albinrad Commendable Apr 26, 2016 10 0 1,510 May 19, 2018 #1 So whenever i turned on my power psu suddenly makes a loud noise is the psu fault or any other component??
Solution Phillip Corcoran May 19, 2018 It's the PSU that's faulty so replace it before it fails altogether because if it does it could damage other components. Don't buy a cheap one - - you need a good quality brand like Corsair or Seasonic.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,144 933 120,140 May 19, 2018 Solution #2 It's the PSU that's faulty so replace it before it fails altogether because if it does it could damage other components. Don't buy a cheap one - - you need a good quality brand like Corsair or Seasonic. Upvote 0 Downvote Solution
