PSU Mosfets dBm level
Spezz
39
Which one of these psu do you think is more silent (mosfets noise, etc.) ?
- Seasonic G-750 750W 80 Plus Gold Modular
- Corsair RM750i 750W 80 Plus Gold Modula
Both are tested in 50ºC stress conditions for 80 PLUS cert. ?
Any recomendations ?
Thank you, !
datguy20 , that Corsair it's made by Channel Well Technology. Seasonic is considered better (quality components) manufacturer (?)
thanks ko888 but in web site were i will buy there no EVGA psu 🙁
cause a friend told me the Seasonic mosfets emitted more noise and Corsair ones were more protected/coated.
thx.
Check the tier list I linked. Both are high quality, the Corsair is just higher than the Seasonic. I don't know about the noise specifically though, sorry.
How about the Super Flower Leadex Gold 750W (SF-750F14MG)?
so other componentes (?):
http://www.ukgamingcomputers.co.uk/capacitor-squeal-coil-whine-explained-a-63.html
A "switching" power supply (like virtually all modern computer power supplies) works by "rectifying" the incoming 120V 60Hz (in the US) AC power into DC (at around 170 volts), "filtering" with capacitors, then using a semiconductor circuit to "chop" the DC voltage around 1000 times a second to turn it back into crude AC. (What's referred to as a "square wave", vs the "sine wave" of ordinary AC.) This "chopped" voltage then runs through a transformer to produce the desired output voltages. The outputs are again rectified to DC and filtered, to produce the desired voltages for the computer.
With this scheme, basic voltage regulation is performed by adjusting the "duty cycle" of the chopped voltage. When the power supply is lightly loaded the circuitry doesn't produce a nice symmetrical "square wave" but instead a series of narrow spikes, and that "spikey" waveform is more likely to produce annoying audible noise in the transformers and other components and is also more likely to produce "electrical noise" that you would, eg, hear in a nearby radio.
Additionally, when a power supply is lightly loaded more of the magnetic field inside a transformer escapes to the case of the transformer and to surrounding components (since less is captured by the "secondary" coil of the transformer), and this "escaping" magnetic field is more apt to cause noise. ]
http://en.gecid.com/power/seasonic_ssr-750rm/
http://hexus.net/tech/reviews/psu/60449-corsair-rm750/
Go with the RM750i.
