[PSU] Need help ASAP!
Triforce
127
Was just gonna order my build online, until I saw this on the psu
EVGA Supernova G2 750w+ Gold:
6-pin PCI Express 4 st, 6+2pin
4-pin 12V 2 st, 4+4pin
then I realised my graphic card is looking for "One 6 Pin and one 8 Pin"
(Gigabyte G1 Gaming GTX 970)
Then I looked at this PSU
Corsair CS 750W 80+ Gold:
8-pin PCI Express 4 st, 6+2pin 750mm
8-pin 12V 1 st, 4+4pin 650mm
ATX contacts 20+4 pin, 600mm
Which PSU is best for my graphic card?
Both of them above is on 750W
How much would I need for SLI? (gtx 970 gigabyte)
What are the models of the PSU's. With EVGA its best to get a b2, g2 or P2 series and with Corsair stick with the TX, HX and AX series(avoid the CX series). Are you planning on running SLI? 750w is usually enough to SLI 970s, for a single card 550w is usually good.
Updated main post!
Are you sure I wont need an EVGA Supernova G2 850W 80+ Gold?
It costs $25 more
What do you mea with "Japanese caps" ?
