[SOLVED] PSU Noise (doesn't seem like coil whine, and not a bad fan either), and screenflickering.
Jul 27, 2022
I've been having issues with my PSU, it's making a clicking noise that's quite concerning, which gets louder, much louder, when under load. It doesn't seem like normal coil whine either. In addition to this, my screen has also started flickering which leads me to believe the power supply might be struggling to deliver power to the GPU. It is, however, able to run games like Cyberpunk with seemingly no other issues than the extremely loud PSU clicks and screen flicker. I'll include videos of both the flicker and noise.
Flicker: https://streamable.com/uqpabd
PSU Noise https://streamable.com/2j0g9f (might be hard to hear if you have a good bass, since the fans might over power the click noise, but trust me it's quite loud)
As you might be able to hear in the video, the buzzing occasionally stops for a split second, then continues.
EDIT: FLICKER HAS BEEN RESOLVED; BAD DISPLAY PORT CABLE
Specs:
AMD Ryzen 7 5800X
ASUS TUF GAMING X570-PRO
CORSAIR HX Series HX850 Platinum
Kingston FURY DDR4 16x2 3000MHz
ASUS Strix GeForce RTX 3070 Ti
D
if in warranty RMA it as there is no easy fix for this without opening the unit.
