Hi
Like many I'm planning to build a htpc, however I'm trying to fit it in a (395mm H x 175mm W) space. If i use an ATX motherboard (which gives me the most options) then i only have about 80mm to 90mm to fit a power supply. i was thinking of going with the Thermaltake purepower but its cutting the space kinda tight. however if i turn the psu on its side then the space is better used. I was wondering will putting the purepower on its side effect its heat dissapation abilities ?
thank jc
Homer: There’s 3 ways to do things, the right way, the wrong way, and the max power way.
Bart: isn’t that the wrong way.
Homer: yea but faster.
thank jc
