My pc build is as follows: Asus Z97 wifi ac motherboard, core i5 4690k processor, 16 gb of RAM, 250 GB samsung ssd 860 EVO, WD Blue 2TB hard drive and seasonic 750 prime gold psu. My problem is that my pc doesn't start when I press the power button. The motherboard onboard power button turns on but nothing happens if I press it. The LAN light also turns on but no fans or other lights turn on. Then around 15-20 minutes later, sometimes longer when I press the case power button suddenly the pc boots up and runs fine with no problem. I kept the pc on for nearly 72 hours before shutting down and the performance was completely normal. But as soon as I shut down my pc it couldn't start again for nearly 45 minutes. Do you think the motherboard is at fault or the power supply?
