I have MSI pro B650m-a wifi and my power supply Thermaltake Toughpower GF1 650W 80+ Gold. My CPU atx slot has 8 female pins then another 4 pins next to it. I cant figure what fits where? I used pc partpicker and it said they were compatible.
Is that my only option? Can't I get an adapter thats way more power than I even need.![]()
Your PSU only comes with 1x 4+4pin EPS connector.
In your current state, you should populate the 8pin EPS connector on the motherboard. I would actually suggest that you return the PSU and get the 850W variant if you want to populate the other EPS connectorbut I'm curious to learn what your PCPartPicker list/build is now.
If you're getting adapters at the start of your new build, you've got the wrong components for said build. You didn't pass along your PCPartPicker build though.
