z_dori
247
hi,
i used Extreme power supply calculator lite 2.5 for this rig:
E6420 (90% TDP)
XFX 8800GTS 320 XXX
1024X2 OCZ 800Mhz
WD 250G
LG DVD/rw
3 120mm fans
i got 283W. can it be?
please hurry, i'm buying this pc 2morrow morning. thanks...
Yes it is true, however the minimum power requirement would be a 400w or greater since you want +12v@22A combined minimum for your rig and recommend a 450w or better which would work out to +12v@26A combined.
z_dori
247
yap i know.
it just that i'm buying tomorrow this rig for a friend, & didn't know if i need to buy a special PSU. with the cheap case i get a 500W 4+4 pin PSU.
@ 85% efficiancy i get 435W truepower. i wanted to know if it's enugh... & if the calculation is right, than it is.
z_dori
247
i was wrong. how can i show here an image of the PSU table?
at voltage 230v~ @ +12V i got 18A, 216W.
at current 5A i got @ +12V 1.0A and blank at W...
max output 500W, true 422W...
it's not enugh right?????
the 283W by the extreme calcolator is for the +12A only, right???
Edit:
is this PSU good for me?
http://www.thermaltake.com/product/power/TR2power/w0101102/w0101102.asp
( i cannot understand Tt tables... the Enermax much understandble...)
& this:
http://www.enermax.com/english/product_Display1.asp?PrID=20
can i overclock with it? or i'll need the 485W ver for that? (32A Vs. 29 A, 30$ more!)
thanks!
for the +12v calc, I usually choose cpu/gpu/hdd/dvd/2 fans (or devices that load up the +12v only, memory / system board loads up the +3.3v / +5v rails). So...
eXtreme PSU calc[/url]"]System Type: Single Processor
Motherboard: Regular - Desktop
CPU: Intel Core 2 Duo E6420 2130 MHz Conroe
CPU Utilization (TDP): 90% TDP
Video Card: NVIDIA GeForce 8800 GTS 320MB
Video Type: Single Card
SATA HDD: 1 HDD
DVD-ROM Drive: 1 Drive
Fans
Regular: 1 Fan 80mm; 1 Fan 120mm;
Keyboard and mouse: Yes
System Load: 100 %
Recommended Wattage: 253 Watts
But, don't forget to subtract the "no load" system board wattage of 38w
253-38=215w or 17.9A at most on the +12v rails combined.
Pad that at the 80% mark, you want minimum +12v@22.4A on your PSU.
The truepower 430w should handle that w/o an issue if you can get it cheap. Go w/ a 500+ unit if you have the budget, they usually handle +12v@35A or so - then upgrades and longevity are part of the consideration.
randomizer
Champion
& this:
thanks!
Yes the enermax 485w would be a good choice, you have some room left over for OCing. The 420w would be good otherwise.
I would definitely go for the 485W, the 420W is cutting it a little close at 29A.
