PSU Power required
thekashyap
17
Hi Guys,
I'm building a DIY NAS. I was wondering abt the PSU requirements. I'm a noob (at actually building things, though I understand teh theory :) ).
Here is the selected hardware:
- Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
- Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303
- "Intel Pentium G630 2.7GHz LGA 1155 65W" with "G.SKILL Ripjaws X Series 8GB"
- DVD Drive: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
- HDD Not decided yet but:
- 4 x WD Red 2TB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822236343,
- or 3 x WD Green 3TB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136874, or
- 3 x Seagate Barracuda ST3000DM001 3TB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148844
AND I WOULD BE ADDING MORE LATER, probably bring up the total number to 6 and then replace only on failure.
- Not sure if it makes any difference to power requirements, but I'll be buying a RAID controller card too. Probably one of the cheaper HighPoint RocketRAID 27xx.
- Wireless Adapter - http://www.newegg.com/Product/Product.aspx?Item=N82E16833166054
I had a look at the FAQ thread with a very related title, but my prime confusion is related to the power required for the HDDs, which was far from answered by that thread.
Thanks
Kashyap
Thanks for the info.
Abt budget, this will be only the second time I'm actually buying a case and first one was with PSU. Without any history or knowing what features make a PSU good/bad, it's really difficult. But let me add that the budget for the NAS itself is around 6-800. I'm planning to reduce the number of HDDs from build if I hit the limit, it's RAID (RA of "Inexpensive" D) after all and I'll add more later.
What I can say for sure is I won't be adding any graphics card anytime soon.
If you really push me for a number: Looking at the list on newegg for 401-450W PSUs (http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657%20600014019&IsNodeId=1&bop=And&ShowDeactivatedMark=False&Order=RATING&PageSize=100), I would say perhaps $40-60, viz around median, should be enough.
There's a %15 promo code that makes it $5 less than the Rosewill right off the bat, then the $15 rebate
So it's $9 less expensive and definitely better
