PSU power? VOSTRO 460/ i7-2600/ GTX 750ti/ 400W RS-400-PCAP-A3
Dec 31, 2018
Hi, I have business line DELL VOSTRO 460 with the following specification:
- CPU: i7-2600 + BOX
- MOBO: DELL 0Y2MRG H67 LGA1155
- RAM: 20GB DDR3 (2x8, 2x2)
- GPU: ASUS GTX 750ti 2GB GDDR5 with 1 fan (GTX750TI-PH-2GD5)
- PC-E: ASUS AC1200 PCE-AC55BT Wifi & Bluetooth adapter
- PC-E: DELOCK USB 3.0 x4 controller
- 1x SSD 240GB & 1x HDD 7.2k 2TB
- 1x fan
- PSU: COOLER MASTER RS-400-PCAP-A3
CPU, GPU & RAM without any OC.
I’ve put a very energy saving GPU (probably only RX 550 could compete), but still I’m a little bit worried about my PSU. Will it be able to handle?
400W theoretically should be fine, but this RS-400-PCAP-A3 has awful opinions and reviews, so I’m a little bit scared.
Thx 4 help.
Did you buy the PSU already? It's not great at all. Id consider getting something decent like this soon, to be on the safe side:
Power Supply: SeaSonic - FOCUS Gold 450 W 80+ Gold Certified Semi-Modular ATX Power Supply ($49.99 @ Newegg)
Total: $49.99
Generated by PCPartPicker 2018-12-31 08:08 EST-0500
Quality and will last you years with no issues.
You can try get by with the CM, but if it's one you've had for a while, Id strongly think about upgrading.
Total: $49.99
Dec 31, 2018
Thx for answers, I appreciate it. You convinced me 100% that I MUST REPLACE MY PSU. No doubt. I don’t want to take a risk to damage my components.
I’ve bought this computer second handed for 266$ (and upgrade ram, gpu, wifi card, usb controller for another 163$). I know it’s not a perfect gear but I would like to use it for 4-5 years.
Especially CPU (despite being old) is tolerable, theoretically I could put a quite strong GPU without bottleneck. i7-2600 has 8193 pkt in passmark benchmark, so not bad for sandy bridge (better than iconic i5-2500k without a huge OC).
I know that I should replace besides PSU: motherboard, case and cpu cooling, but it’s probably not cost efficient (it would costs another 200-250$). I don’t want to “over-invest” my desktop. So I will replace PSU only, use this computer for a few years and buy another one.
So I’m looking for PSU only. PSU should fulfill those requirements:
1) fit in VOSTRO 460 case (every PSU will fit?);
2) compatible with other components (every PSU will fit?);
3) top notch quality, so I can sleep well;
4) quite big power reserve, co I would possibly be able to change GPU in the future without another PSU replacement.
I’m a layman, don’t know nothing about PSU and never install PSU myself. But I’d like to do it myself for savings, maybe some youtube video will help me with this :).
I’m using this online shop for buying new gear (unfortunately it doesn’t have english version): https://www.morele.net/komputery/podzespoly-komputerowe/zasilacze-61/
But I’m open to buy PSU second handed, if offer is reliable and cost-effective.
I’ve got some local second-hand offers, like:
- Corsair VS650 (150PLN ~40$)
- COOLER MASTER G550m 550W (RS-550-AMAA-B1) (150PLN ~40$)
- ANTEC 550W 80 PLUS BRONZE (165PLN ~44$)
- Corsair AX760 760W (CP-9020045-EU) (320PLN ~85$)
- Corsair HX750 750W Platinum BOX (350PLN ~93$)
- Corsair rm850x gold box 850W (390PLN ~104$)
- Corsair RM 1000x (400PLN ~106$)
My budget is 400PLN (~ 100$), but less would be nice :).
If you wanted headroom and quality then something like this: https://www.morele.net/zasilacz-corsair-rm550x-550w-cp-9020090-eu-779365/
I would not buy a second hand PSU. Just my own preference. So I won't advise you to do it.
Dec 31, 2018
I’ve decided to buy second-hand SEASONIC G-550 for ~50$.
Specification:
- 550W, 540W on +12V;
- 80+ gold;
- DC to DC;
- japanese capacitors;
- 1/2 modular;
- 4-years old;
- used with ASROCK Z87 Extreme4 + i5-4690 + GeForce 970.
Maybe it is mistake but I’ve got mental blockade and don’t want to buy PSU that is worth 1/3 of my desktop value (266$). I know that it’s risky, but whatever, what will be, it will be :).
Thx for help, I appreciate it. Topic may be closed.
Well, good luck so :) The Seasonic unit is an older one, but it was very decent in it's day. Hopefully it will last for you.
To close the thread you must select best solution/answer.
