G gtx infinity Reputable Dec 6, 2015 5 0 4,510 Dec 6, 2015 #1 Can a cx430m psu handle two msi gtx 750's? and an amd fx 6300? Plz help, I need to know so I can return this if I need to
Solution heman0286 Dec 6, 2015 gtx infinity : Can a cx430m psu handle two msi gtx 750's? and an amd fx 6300? Plz help, I need to know so I can return this if I need to 2 GTX 750's???? GTX 750's doesn't support SLI....
M Mark_1970 Reputable Nov 14, 2015 1,391 3 5,960 Dec 6, 2015 #2 No way can it ,return quickly while you can and never buy another CX. bad psu and not enough power too. get a 750w Upvote -1 Downvote
heman0286 Reputable Jul 28, 2014 287 0 4,960 Dec 6, 2015 Solution #3 gtx infinity : Can a cx430m psu handle two msi gtx 750's? and an amd fx 6300? Plz help, I need to know so I can return this if I need to 2 GTX 750's???? GTX 750's doesn't support SLI.... Upvote 1 Downvote Solution
Mousemonkey Titan Sep 3, 2006 59,462 17 92,965 Dec 6, 2015 #4 Dual GTX750's seems a bit pointless because as already pointed out the GTX750 does not support SLi, as for the PSU I run a 380 on a CX430 and have had no issues so in theory it probably could run two low power GPU's like the GTX750. Upvote 0 Downvote
G gtx infinity Reputable Dec 6, 2015 5 0 4,510 Dec 6, 2015 #5 I know, I just realized this morning that gtx 750 does not support sli lol thx for the help though Upvote 0 Downvote
