zenx :
Hey guys
Sorry to interrupt... So from what I've gathered you basically tried everything but your computer still sometimes starts up with no video at all.. am I right? Next time it happens unplug your usb devices.. especially your keyboard and boot up again...
Funny thing is.. I've seen this very same issue once and I was about to yank my hair out one by one because I've tried everything.. and I was at the point where I thought the GPU simply died but it still couldn't be since sometimes it would start... So.. out of desperation I disconnected everything but the power and display cables... like magic it started up...
Turns out usb keyboards tend to have very short cables.. and from all the pulling on the keyboard the insulation on the small wires inside broke and the cable shorted somewhere... who knew USB shorts would prevent the gpu from running... So yea.. simply plugging in another keyboard (which was much cheaper than a GPU
😀 😀) solved the issue then.. and I'm guessing something similar is happening in your case as well!
Cheers
ohhh!!! thanks for the answer... ok, first I tried Vic's suggestion to remove my gpu and plug my monitor to mobo, it works now without mobo... I saw some forums that mobo built in gpu is interrupting the actual gpu driver itself so disable the built in gpu to mobo via safe mode is my option too...
I'm using AMD drivers and Razer keyboards and mouse just to be more informative
😀 ok gonna try your suggestion tomorrow since I just got home and my problem persist when my desktop turns off for a long time
😀 cheers!
UPDATE: when I plugged my gpu and start the desktop the desktop continues as normal and while surfing the net my desktop suddenly crashes. It sound like a broken windows bgm or something and if I wasn't mistaken my fans inside the desktop start spinning so fast! I hard reset my desktop and so far it's ok for now...
