Psu problem or something
rushiop
8
hi sorry for my english.
i have this problem.
some games crash or give me black screen and bsod some don't
I think it's the psu i don't know, i already test the sistem without overclocking the cpu and vga.
this happen only while in game, no problems while web browsing or watching movies.
my specs:
fx 8150 4.1 ghz
xfx 7770 (gpu 1095 memory clock 1245)
4 gb ddr3 1333
2 hdd sata 149bg 1 usb 149gb
2 fans 120mm
psu cooler master rs-460-psar-j3
please help. thanks
1) mb Asus m5a78l-m usb3
2) game that crash so far mechwarrior online, cs:go, no more room in hell, natural selection 2, arma 2.
3) i use cpuid hardware monitor, gpu no more than 60c, cpu 40c, mb 50c in full load.
i got a new error message with cs:go
AMD Display driver stopped working and has recovered i always get this message with mechwarrior online
i forgot to mention that i just clean install windows 7 64 bit
hwmonitos Temperatures
vga max 59c
cpu max 40c
mb max 47c and 38c
i read with My event reader one event who say that the north bridge is failing
minidump:
Dump File : 031614-21637-01.dmp
Crash Time : 16-03-2014 23:21:48
Bug Check String :
Bug Check Code : 0x00000124
Parameter 1 : 00000000`00000000
Parameter 2 : fffffa80`04cfb038
Parameter 3 : 00000000`00000000
Parameter 4 : 00000000`00000000
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+49f14c
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.20714 (win7_ldr.100517-1050)
Processor : x64
Crash Address : ntoskrnl.exe+49f14c
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\031614-21637-01.dmp
Processors Count : 8
Major Version : 15
Minor Version : 7600
Dump File Size : 262.144
When you use the fx8150 with the AMD 7xx chipset MB, then it is a little bit tricky because the MB manufacturer said the MB is compatible to the cpu, but it does not mean the PC can run stable. Because the MB only has the 4+1 power phase (VRM) also it does not come with the heatsink, it is easy to overheat and also that does not has heat sensor. So that the PC sometime will bsod or freeze up like that. Check the link, M5A88-M (EVO) has the same # power phase as your MB, and it can't handle FX8150 at stock. https://spreadsheets.google.com/spreadsheet/pub?key=0AgN1D79Joo7tdE9xMUFlMEVWeFhuckJEVF9aMmtpUFE&gid=4
I add the link you can try to use the fans to cool down the VRMs section like they do. http://www.overclockers.com/forums/showthread.php?t=733680
And let me know it works or not. Thanks.
