Recently, I had my PC moved into my bedroom and hooked directly into my TV. Everything was working fine for a few days until I noticed my PC would shut off, with the power LED blinking on and off pretty slowly. It only blinks like this when the PC is put in sleep mode or in hibernation.
The power button does not work whenever I try to turn it back on. It doesn't respond to keyboard or mouse commands either. My only option was to flick the power supply switch.
After the second time this happened, I had the PC moved back to my basement, thinking it was some sort of wiring problem with my room. It worked for a few weeks, but the same situation occurred.
I've owned the PC for a good 3 years, but I'd like some advice on what to do.
