PSU quality: XFX PRO 550W vs. Corsair CX 650W
Wort
381
Hey. I'd like you guys to give me some opinions on those 2. I know the XFX one has 100W less, but I want to know which one is better overall? I want to buy R9 290x Tri-x so I really need to know if they're capable of doing that.
CX 650W is known to fail on high loads, so avoid it completely, its very poor quality. XFX Pro 550W is much better quality, but 550W is pushing it too high. And have you considered the GTX 970? Its on par performance wise, cheaper, more efficient, and will work on a 550W PSU.
Where is that information sourced from? Power target and TDP are the same when core is at the same clock (most people overclock the cards clock 40Mhz to be at the same speed as the X variant). The R9 290 is the locked opposer, but has the same overall power consumption. As for it's stock clock, the TDP is less as it is 40Mhz underclocked, but as stated above, people tend to change that. 40Mhz on the core clock and a few locked cores does not drain 15W more.
http://www.techpowerup.com/gpudb/2397/radeon-r9-290.html
http://www.techpowerup.com/gpudb/2460/radeon-r9-290x.html
Thank you all for your answers. I'll stick with XFX 550W then. It has been working great since I've bought it.
My friend sells Corsair CX 650 which he doesnt use anymore and I bought my XFX 550W 6 months ago, so there's no site to provide 😛
Corsair CX series aren't too bad, they get a bad rap because of cheap capacitors that may reduce the life span.
The XFX Pro 550 is a better qualirty supply.
AMD specifies the R9 290X with a TDP of 250W.
Factory over clocked card might pull 290W.
XFX Pro 550 is rated at 44A on the +12V rail.
With a 125W CPU, you would be loading this to about 79%.
Anything under 80% is OK.
Even better if you have a lower powered CPU.
The GTX 970 mentioned above is faster and uses less power than the R9 290 if you have the option.
The thing is that I'd buy R9 290x from my friend for 250€. New GTX 970 is 330€+, which is at least 80€ more. If 550W PSU can handle the power of R9 290x TRI-X, I'd go with that card, because it's still a great card for quite low price.
I just noticed your CPU in your signature. This is an 84W CPU, a little higher with over clocking.
You should comfortably stay under 80 % of rated capacity on the +12V rail.
You should be fine to get the R9 290X if you want.
