Psu question for graphics card
Nov 29, 2013
11
Hi all,
I had the pleasure of buying a gently used 7850 off ebay, and have now realized that i have a sparkle 350 watt psu under the hood in my computer. Will it be able to handle a sapphire 785 2gb or will i need a diff psu? I've looked around and AnandTech said that most it pulled was 310 watts at load. But the catch is that the sparkle doesn't have pci 6 pin and i will be doing 2 molex to 6 pin conversion so take that into mind when you are suggesting ideas as well.
Here's the psu link so that you can work out amperages and stuff like that: http://www.newegg.com/Product/Product.aspx?Item=N82E16817103012
Video card:http://www.newegg.com/Product/Product.aspx?Item=N82E16814102999
Oh ok if you feel comfortable getting a molex to 6 pin adapter, and you are certain 310w is your total usage at max load then it is up to you. I personally like to make sure I have a good amount what I need for power so I have some extra headroom for when I overclock. :)
I would still suggest getting a new PSU entirely. If it does pull 310 watts at load then the rest of your system will have 40 watts to work with. That wont end good you will probably damage your hardware.
