[SOLVED] PSU recommendation & home electric grid problem
Oct 1, 2020
9
Hi all,
I have some electric grid problem at home (probably non stable voltage during load evening hours ). As a result my computer reboots all of sudden. However, because this happens only with one computer, I believe that my PSU does not handle it well. Here is the model that I have (it is eight years old): https://www.amazon.com/Seasonic-S12II-380Bronze-380W-Power-Supply/dp/B002A1CRS0
What you will recommend to do? Will replacing PSU will help? If so, what are your recommendations (model, Watts)?
Many thanks.
Daniel
Hi all,
Many thanks.
Daniel
That PSU was never designed to last 8 years. I'd replace it but you need to list your specs and budget for a recommendation.
Please list your specs in this format:
CPU and cooler:
Motherboard:
RAM:
Storage:
GPU:
PSU Brand, model and age:
Display resolution and refresh rate:
OS:
Thank you!
Here is my spec: spec
I need probably not a specific model (because I am not sure that I will be able to purchase it) , but more a general idea (how may watts, anything else).
BTW, will any PSU work with a PC? Van it damage ?
CPU and cooler:
Motherboard:
RAM:
Storage:
GPU:
OS:
Thank you!
How many actual hard drives do you have. Some of those 10 drives listed must be partitions. Just to verify, I didn't see a GPU listed so I assume you're using Intel onboard graphics.
Thank you.
But in general, the more watts the better (and more expensive) ?
Is there any issue of compatibility or I can purchase any PSU 450+ watt?
You can easily run your system on a 450 watt PSU. A corsair CX450 would be fine for your specs and is not expensive and leaves you a bit of room for some upgrades later on.
