PSU select HELP.
CritHit
17
HI i am making a new pc, but idk what watt should my psu have, so here is my pc:
Motherboard: ASrock pro 3 r2.0
CPU: AMD FX 8320
GPU: MSI R9 270x Gaming 2GB
1 optic unit
8 GBs RAMS 1600 MHz ( 2x 4GB )
1 HDD 7200 rpm.
+ a Z3 case with 3 vents.
I wanted to get a sirtec element power with 500W but idk if is enough soo..
Tell me please what wattage should my psu have. THX
Honestly I never heard of that psu and there's not much information about them on the internet so I recommend you stay away from it.
The minimum requirement for a r9 270x is 500W with a minimum of 30amps on the 12 volt rails with 2 six pin pci power connectors, so you should check if your psu meets those requirements
If you have about $60, heres the xfx psu I was talking about, http://. Its a high efficiency psu that delivers clean continuous power and is made by seasonic
