PSU wattage help?
lukeg310
17
Hi Guys,
I am building a budget gaming rig. I am not sure what kind of PSU I should get, id like to SLI down the road. I was thinking of going 750Watts but I am finding varied answers, some are saying thats fine while others are saying go to 1200watts. Any suggestions?
What do you guys think of this PSU?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152044&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
CPU: i5 4670K
CPU Cooler: Corsair H100i
CPU Paste: Aritc MX-2
Mobo: Asrock Z87 Extreme3
Ram: G.Skill Ripjaws X Series 8GB DDR3 2133
Videocard: PNY 770GTX (I plan on going SLI down the road)
HD: SSD OCZ 240gb
better to go with a better built psu.
PCPartPicker part list: http://pcpartpicker.com/p/2Ym1
Price breakdown by merchant: http://pcpartpicker.com/p/2Ym1/by_merchant/
Benchmarks: http://pcpartpicker.com/p/2Ym1/benchmarks/
Power Supply: SeaSonic M12II 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($97.98 @ Newegg)
Total: $97.98
(Generated by PCPartPicker 2013-11-04 20:30 EST-0500)
A good quality 750W PSU with 4 x PCIe 6/8 pin connectors is fine for those 2 cards. But I would recommend staying away from Raidmax. Look into Corsair, Seasonic, Antec, etc. Here is a "quality" list: http://www.eggxpert.com/forums/thread/323050.aspx
The GTX 770 is a 230W card maxed out. That's 19.2 amps per card on the +12V rail. The i5-4670 is a 84W (7 amp @ +12V). Together they would draw 45.4 amps. The MB can draw from 10W to 50W. The drives, etc are miniscule. So look for a 750W or bigger PSU with at least a 60 Amp combined +12V rail(s) for some headroom.
