Question PSU Wont power on even when connecting green and black pin.
Apr 10, 2019
9
I have an Antec Neo Eco 620W psu which won't power on when in pc or by shorting the green and black pins.
Zephyl
Commendable
Mar 13, 2017
377
51
1,740
19
Make sure the outlet it's plugged into has power. Make sure the switch on the back of the unit is in the "I" position. If not, try the "O" position just to be sure. If it still doesn't work and you're sure you're shorting the right pins, the unit is faulty.
