hello guys , so i am worried about my psu sound. i need to know if this normal or not and should i be worried about it? here is video link (volume up)
View: https://www.youtube.com/watch?v=fOU91ZZaLJ0&ab_channel=MusicSpectrum
thanks for the answer, i need to know is it danger for pc? i live in georgia (caucasus)Regardless of the noise, replace it. It sounds like bad coil whine from cheap components, it was never that good when new but with this coil whine, I'd be getting rid.
If you want recommendations on a new one, state which country you're in and which etailer you're using.
i5 9400f , h310-k r2.0 , 16 ram (2400mhz) , gtx 1070 rog strix , 1tb hdd , 120ssdWhat are the specs of your computer?
i think that sound comes from vibration. when i touch case strongly it stops making this noice , could it be cooler?Regardless of the noise, replace it. It sounds like bad coil whine from cheap components, it was never that good when new but with this coil whine, I'd be getting rid.
