PSUs 101: A Detailed Look Into Power Supplies
  • Thread starter Thread starter Guest
  • Start date Start date
In your list of top-tier capacitor manufacturers you missed out on some of the better american and european manufacturers, while these may not be used on many consumer-grade power supplies they are definitely top-tier and if you were to find them you would be happy. I suggest the addition of at least:
Cornell Dubilier (USA)
Illinois Capacitor (Now owned my Cornell Dubilier)
Kemet Corporation (USA)
ELNA (Japan)
EPCOS (TDK company) (Germany)
Vishay (USA)
Würth Elektronik (Germany)
Thank you very much for the list you provided. I am aware of almost all cap brands that you mentioned but unfortunately so far I found none of them inside a desktop/consumer grade PSU. I will think about it however (and also make a research on these cap brands), if I should include them as well inside my list.
There is a very high probability you have seen PSUs with several Kemet capacitors in them. You never noticed them simply because SMD capacitors are too small to carry logos, brand name or even value designations.
The other brands are mostly found in specialty applications such as lab instruments, industrial machines and high-end audio.
I only read 2/3 of it, but it's a good article.
I basically have committed PC heresy with my cx600m. However I think that I'm in the clear with my 65w CPU and 145w CPU. I'd bet my total power draw is actually below 300w, the supposed highest efficiency point of a PSU.
As a gamer, not a professional, I think it is better to get low power parts, and get a higher rating than you need, rather than get high power parts and high quality PSUs.
Additionally, if you compare power consumption of a typical system from today to one from 5 years ago, power draw is considerably lower, with the exception of certain graphics cards. *cough* 390x *cough*
I decided to sign up at Tom's forum, and the only reason was to state how excellent is Aris's article!!!
Thanks Aris for this very useful article on behalf of us all who want to learn the basic knowledge for PSUs.
Haven't finished it yet, but i'm very anxious for it !!!
I'm glad there are people dedicated to this but I'm not. I can't even read all of the chapter titles in this article. I disagree with the importance you place on this and all of the references you made to this being crucial knowledge.
PSU and MB are insignificant to me and I can blindly pick one by reviewing user comments from newegg in about 5 min, and it will last for years. For less than $100 each I'm set for nearly a decade.
CPU and gfx card now that affects fps and is over $1000, actually the most important part to me.
I heartily dissagree, user are not the best way to judge reliability, and a bad powersupply is at fult most of the time there is a hardware issue. Further a power supply should last more than one system build, and in general I keep mine for a decade at a time at least. So an investment in a good power supply is not a waste, and a bad one will kill that precious $1000 GPU or CPU. The demo dart power supply on the motherboard is a similar story, however in general they are of higher quality than a cheap mains supply.
As well as SMT ceramic capacitors, Kemet makes through hole aluminium electrolytic capacitors. These are of high quality, though not as well known as their SMT capacitors. They also make high quality polymer SMT capacitors that are used as bulk capacitors on the power distribution circuitry on laptops and other devices.
ELNA (Japan)
Vishay (USA)
Decide to include them in the article for reference and to show also that besides Japanese caps they are also some good US and German brands. Thanks again for your input!
You probably buy cheap hard drives, too.
Enjoy your ticking time bomb. Because a cheap PSU and cheap motherboard is the quickest and surest way to a total system failure.
One or more bridge rectifiers fully correct the AC power stream after it passes the EMI/transient filter.
You mean rectifies. A bridge rectifier converts the AC voltage into DC voltage.
The name bridge, comes from being a bridge of four (power) diodes. ( image: Source: Play Hookey)
I had it rectify and not "correct" but the proof editors changed it. Sorry will fix it ASAP. Of course they rectify and this is why they are called bridge rectifiers after all.
I'm curious as to why you think this. Yes, the CPU and GPU are doing the number crunching, but what do you think holds them together and lets them communicate to actually do their work? The motherboard. What do you think feeds them? The power supply. What manages the power delivery to the CPU? The motherboard. If either of those things goes out, how do you expect to still play games? Saying you only care about the CPU and GPU but not the rest is like dropping a monster engine into a car without first checking whether the chassis and transmission can handle the extra weight, power, and torque.
No one has said you have to spend hundreds on them. A good PSU in particular can be had for $50 - $75 depending on application. I've actually never spent more than $75 on one, but that doesn't mean I was picking blindly.
Great article, maybe the best I've read about how PSU's work and what are the details you should look for, as an electronics engineer is good to remember some basic concepts that I haven't used in a long time haha.
Excellent article, and certainly one of the most thorough. Pulls back the veil, if not a little, on the huge complexity that powers our modern lives.
its too long article . I have read half and inshallah will read the other half sometime . It's easy to understand for me as I am electrical engineer and now my doubts are getting cleared for PSU's
Reactions: RGB_RGB
