[ Moderator note: Solved per OP.]
I hope someone can help to find the cause of my PC crashing.
The system is less than six months old
I play games sometimes, all of them except PUBG run great on 4k Ultra/High. But PUBG can sometimes cause my PC to suddenly shut down. I can't catch any patterns, it can happen regardless of the map, the intensity of the game events
After such situations, I usually manually check the temperature of the heatsinks on the CPU and video card, but they are not hot - well warm, but not hot.
Also, after such a shutdown, I can't switch on the PC right away - after pressing the start button on the system unit, nothing happens. But if I manually switch off the power supply (with a switch on the power supply itself) and switch it on again, the PC starts immediately.
Games where everything is good:
- The Division 2
- Horizon Zero Dawn
- DayZ
- The Division 1
- The Invincible
- Hunt Showdown
- Ghost Recon Wildlands
- Red Dead Redemption 2
- Warframe
Hardware
HWInfo logging was enabled from the start of the system, and after a certain period of time, the system was loaded. Log file is in attachments.
By load, I mean gaming PUBG.
Idle stats:
https://drive.google.com/file/d/1K_exzet02ZeK5aE6u0j1QZt3243JunHO/view?usp=sharing
I also attach some screenshots of HWMonitor with the load in some games (3 screenshots for each game - taken over a certain period of time each):
Horizon Zero Dawn
https://drive.google.com/file/d/1wU5oQicNSjK3-naCxEYVODUiwaDH1Zp3/view?usp=sharing
drive.google.com
https://drive.google.com/file/d/14NYPxVMvl-45JP4PI1WTQwTsJ5gsFDrE/view?usp=sharing
The Division 2
https://drive.google.com/file/d/1q3_MvEMf3NdZUFp0t_zw3Ll1gu-dlyU6/view?usp=sharing
drive.google.com
drive.google.com
PUBG
https://drive.google.com/file/d/1inRj5F-MT5lNhJ8VQKGpc737jIb8yFq8/view?usp=sharing
drive.google.com
drive.google.com
Log file:
https://drive.google.com/file/d/1j40CGeoVkvERrmVOo0Xkc6VBjFkYsLcC/view?usp=sharing
- The Division 2
- Horizon Zero Dawn
- DayZ
- The Division 1
- The Invincible
- Hunt Showdown
- Warframe
Hardware
Motherboard | Asus TUF Gaming B550-PRO | BIOS Version 2204 |
CPU | AMD Ryzen 9 5900x | The thermal paste was replaced 7 days ago |
RAM | 2x16 Corsair Vengeance LPX DDR4 32GB 3200MHz CL16 (CMK32GX4M2B3200C16) | RAM is installed into A2+B2 slots. D.O.C.P activated. |
SSD 1 | Samsung SSD 990 Pro with Heatsink 4 Tb | Connected in PCIE 4.0 mode |
SSD 2 | Samsung SSD 970 EVO Plus 1 Tb | Connected in PCIE 3.0 mode |
GPU | Asus ROG Strix RTX 3080 Ti | Plugged directly into the motherboard (horizontal installation). Connected to Asus VP32UQ Monitor by Display Port cable |
Power Supply | Be quiet! STRAIGHT POWER 11 850W | Connected directly to a wall |
Processor Cooling | Be quiet! Dark Rock Pro 5 | |
Case | Be quiet! Pure Base 500 | |
Case fan 1 (front) | 3 x Be quiet! SILENT WINGS 4 120mm PWM high-speed | Connected via Noctua NA-SYC1 4-Pin Y-Cables |
Case fan 2 (back) | Noctua NF-A14 industrialPPC-3000 PWM 140mm | Exhaust fan |
Case fan 3 (top) | 2 x Be quiet! Pure Wings 2 140mm | Connected via Noctua NA-SYC1 4-Pin Y-Cables |
Idle stats:
Horizon Zero Dawn
The Division 2
PUBG
Log file:
